Old 10-02-2005, 03:21 AM
rockertype's Avatar
rockertype rockertype is offline
Default 4L80E In A 67?
Does anyone know of a place that makes a crossmember for installing a 4L80E in a 67 Camaro? I'd rather not spend the rest of the season trying to fabricate one myself! Bowtie Overdrives does not have one for the F body yet. Thanks in advance guys.
Old 10-02-2005, 06:31 PM
protour's Avatar
protour protour is offline
For the Chevelles...The 4l60e and T-56 crossmember is the same for a 4l80e tranny... Not too sure about Camaro's though?
Just some food for thought.
-Matt
Old 10-02-2005, 06:50 PM
camcojb camcojb is online now
-Matt
I guess you guys can slide the crossmember back on the frame rails? There's a big difference in how far back the trans mount pad is on a 4L60 and a 4L80. Plus on the Camaro's you can't move the crossmember back nearly enough.
Old 10-02-2005, 07:07 PM
protour's Avatar
You half framers you! I actually was able to pretty much use my factory tranny crossmember holes The tranny mount of course differs but the crossmember itself is nothing different.
-Matt
Old 10-02-2005, 07:18 PM
-Matt
That's weird. The 4L80E is at least 6-8" further back for the mount pad than the 4L60's. I have no idea how you could use the stock holes. The mount is a normal TH350/400/whatever deal, at least as far as bolt pattern.
The 4L80E is longer than all of them, and the mount pad is literally at the end of the trans right under the rear seal. Not just after the pan with a tailshaft housing hanging behind it.
Old 10-02-2005, 07:34 PM
protour's Avatar
Did I forget to mention the crossmember was reversed? I stink I did
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 10-03-2005, 01:50 AM
rockertype's Avatar
Matt, are you saying that you used a 400 crossmember reversed - that reached far enough back to grab the mounting holes on the trans?
Old 10-03-2005, 02:44 PM
protour's Avatar
Essentially yes. I used the BMR conversion kit but the crossmember is pretty damn near identical to the stock one. I'd give it a go
-Matt
Old 10-04-2005, 02:34 AM
rockertype's Avatar
Thanks Matt. I will have to give your idea a shot first!
1967 FIREBIRD: Street Car Days 406 cid = 11:46 ET http://www.spottsperformance.com/ima...lyPowell67.JPG
Old 10-05-2005, 03:48 PM
protour's Avatar
No problem budday! I like to save a buck here and there and when I can, I like to let other car nuts know. I find more fun in building a budget car then a "Heres my Visa card". Now before someone bends me over for that comment. Those builds can be equally as fun.
-Matt
