Old 04-04-2009, 12:11 PM
rallye455 rallye455 is offline
Default Using Dynamat ????
Where are the best places to put Dynamat that give you the best results? Would puting it on the roof under the headliner be beneficial?
Old 04-04-2009, 08:57 PM
hifi875's Avatar
hifi875 hifi875 is offline
Default dynamat
everywhere, floorpan doors , trunk, firewall
Old 04-04-2009, 09:28 PM
Flat areas. Contours and stamped areas don't vibrate like flat areas do. So if you're on a budget, you'd be best served by putting any vibration damper such as Dynamat on the areas that are flat.
If you want sound control such as cutting down on road noise, you shouldn't be using Dynamat anyway. Dynamat is for vibration control or panel dampening. This will make a door or floor feel more solid when you close the door or knock on the panel. It'll help with road noise from the simple idea that a thicker piece or solid material will be harder to hear through. To cut down on road noises and make it quiet on the inside, go with a barrier. You can use jute backing which is what's below the carpeting in a house but it absorbs water like a sponge. It's cheap and works great though. There are other materials on the market that are better designed for the automotive environment. Closed cell foam is supposedly the new hotness.
Check out this company. They make better products that Dynamat.
http://cascadeaudio.com/car_noise_control/index.htm
Dynamat makes good stuff but they advertise better than anyone else. They aren't the best by any means.
Old 04-04-2009, 11:57 PM
skatinjay27's Avatar
most benificial areas are the wheel wells, firewall and doors, thats where youll notice the biggest difference...
AJ
Old 04-05-2009, 05:09 AM
Thanks for all the replys......
Old 04-05-2009, 05:23 AM
amaronut amaronut is offline
Double it up on the firewall, plus use use silver foil duct tape on all of the seams. It looks good but helps eliminate getting the black goo everywhere when you crawl in and out of the car......
Old 04-11-2009, 08:20 PM
rdplyr rdplyr is offline
1979 Trans Am WS6- the plan is to build a Gen3 6.6
1996 Formula WS6
__________________________________________________ __________________________________________________ _______________________
I checked out your site. If you were about to do the interior on a 68 camaro. What would you use off the materials on your site to provide the greatest amount of vibration damping and noise reduction?
