Old 10-03-2005, 06:31 AM
T Bell T Bell is offline
Default Framed stripper
Gotcha. I am trying to strip my frame myself with a sander and wire wheel (to save a few bucks instead of chemical or soda blasting). How do you clean the inside of the frame rails? I've heard of putting a chain to a drill but not certain how this is setup.
Old 10-03-2005, 06:34 AM
68protouring454's Avatar
Default cleaning inside
not gonna do it, need it chemical dipped. i would get outside good and clean and painted, i doubt in the good weather use the car will see from now on it will ever be a problem
jake
Old 10-03-2005, 07:26 AM
astroracer astroracer is offline
Ditto on Jakes comment but you could knock a bunch of junk out of the rails with a pressure washer. Do that, let it dry out real well and spray in some POR15 to seal her up. Best you can do without resorting to dipping.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 10-03-2005, 10:06 AM
trapin's Avatar
trapin trapin is offline
A chain hooked up to a drill??!!! From a chain saw I'm assuming? That's the craziest thing I've ever heard. Sounds pretty dangerous too.
T Bell...it cost me $75 to have my frame chemical-stripped. It's money well spent. Believe me. Get it chemical-stripped and buy an undercoat sprayer from Eastwood to coat the inside of the frame with POR-15.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 10-03-2005, 03:24 PM
BC69's Avatar
BC69 BC69 is offline
Come on...how many of us were tempted to make Stripper jokes. "Framed Stripper"!! I was just waiting all day for the sick humor to come out! But maybe its just me.
In memory of those gone before us
In gratitude for those who care.
Old 10-04-2005, 06:27 AM
ha ha ha. I thought it would've came alot sooner too.
Trapin, did you spray your whole subframe with that sprayer? Did you add any thinner?
Old 10-04-2005, 06:47 AM
trapin's Avatar
T Bell.....just the inside of the frame, and no I didn't need to thin it. I only used the wand, the tube portion you see in the picture was not needed.
The outside I painted with a brush. Make sure you use their 'Metal Ready' product on the outside of the frame. I didn't, and now some rust is peaking through in some areas.
Tony Rapin
Old 10-04-2005, 07:51 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Better than a stripped framer....
Jim
