Old 04-08-2009, 09:26 PM
specialized199 specialized199 is offline
Default Anyone use Delta Headlights?
Has anyone put in the Delta H4 headlights? I bought them and put them in. The passenger side is working good but the drivers side doesnt seem to have the same output and I need to have the highbeam plugged in or it is even less bright. Also the drivers side high beam is on but extremely dull all the time, causing my high beam dash light to always be partially on. When I turn the high beams on the passenger side makes the Delta brighter but the drivers side turns the stock high beam on. Keep in mind the passenger side high beam has never worked. Would this just be bad connections on the Delta on the driver side? Driving on the highway my high beam dash light while somewhat flicker. Any help? Anyone else have these lights or similar problems? thanks
Also what are any other better options for headlights/visibility at night? Anyway to retrofit a HID?
Old 04-09-2009, 06:59 AM
ProTouring442's Avatar
Sounds like you have a ground problem. Check your grounds and you will probably fix both the poor light output as well as the high beam indicator.
Shiny Side Up!
Bill
Old 04-09-2009, 08:08 AM
BobB66SS BobB66SS is offline
Have those Xenon bulbs in my car, had the same issue. Had to add the recommended relays in order for them to both light up with the same intensity.
Bob - Mooresville, NC
'66 Chevelle SS (461, T56)
https://lateral-g.net/members/bowe/
Old 04-09-2009, 11:25 AM
Where is this relay? How hard to do? Thanks
I will be checking many grounds as well anyways
Old 04-11-2009, 08:53 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
I have them in my car and they work great!
Though my car was already wired with relays for the high and low
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 04-12-2009, 07:41 AM
One relay per headlight, 2 relays per harness from Painless thru Summit.
http://store.summitracing.com/partde...0&autoview=sku
I only did the low beams; high beams don't get used enough to worry about it. Toughest part was finding somewhere to mount/hide them.
Old 04-12-2009, 09:11 AM
130fe 130fe is offline
Thumbs up
I used this APC harness http://cgi.ebay.com/ebaymotors/APC-U...2em118Q2el1247 > Here is a good writeup at camaros.net on it- http://www.camaros.net/forums/showth...ht=apc+harness I have had this harness for 7 years with no problems, lights are might brighter.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
