Old 04-14-2009, 10:42 AM
Viperlover's Avatar
Viperlover Viperlover is offline
Default HP gains over stock heads?
I've got a 355 in my 71 monte with shorty headers, comp thumpr cam (the small one), performer rpm intake and a holley street avenger 670.
What sort of power boost would I see with some good heads?
Old 04-14-2009, 12:58 PM
hectore3 hectore3 is offline
You are going to have to be more specific on your combination. Like: compression,cam specs etc. Gains are based on parts working as a system together.
You have a myriad of choices based on a Chevy small block heads that have the potential for power/torque. Think of a combination then we can work from there. ---Good Luck.
Old 04-14-2009, 01:46 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Not apples to apples but here are some real world numbers I experienced
9.8 to 1 383 mild street strip car with mild ported 882's consistant 8.20's in the 1/8th. No other changes than a set of Iron Eagle 200cc heads out of the box and the car woke up instantly to 7.60's best thing I even did to the car.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 04-14-2009, 03:21 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
It all depends.
You spend the money on a good set of heads and you "may" get an extra 30-40 horses.
It all depends on the heads you buy and how they work in conjunction with your current set up.
