Old 04-20-2009, 12:00 PM
RBR's Avatar
RBR RBR is offline
Default 71 nova with 396 header ?
I'm helping a friend with his car and have found that the drivers side header is hitting the steering box. We just switched to a DSE power box and are now looking for headers that will clear. Or would going to a rack/pinion set up be another option for clearance. I've seen some cast block huggers that might work, just not sure if that is the answer. Thanks in advance for any help. The car started as a 6cyl. and was converted to a BB 396. I also thought maybe the frame to motor mounts may be for a SB. Not sure how much that could change things for clearance.
Old 04-20-2009, 01:00 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
I would contact DSE and see if they have a part number you can use otherwise beat fit paint to match
Old 04-20-2009, 01:14 PM
I'd check the mounts to see what you have. The SB mounts could cause some clearance issues with steering box. The BB mounts offset the engine to the passenger's side a little if I remember correctly.
John
Old 04-21-2009, 10:50 AM
RBR's Avatar
RBR RBR is offline
Thank's were looking at the mounts now.
