Old 04-21-2009, 01:34 PM
evilzee28 evilzee28 is offline
Default traco fuelie heads
I've got a pair of iron 2.02 fulie heads & I noticed that on the camel hump it has the name Traco stamped inside an oval. Also it has H 63 & 215 stamped on them. Does anyone have any idea as to what this could mean? The heads have been seriously ported at some point in their lives, could this have been done by Traco? Thanks.......Nige
Old 04-21-2009, 02:40 PM
Steve Chryssos's Avatar
Probably means they're worth a pretty penny to a vintage racer. Fuelie heads--even ported fuelie heads cannot hold a candle to modern designs. So from a performance standard, it's better to take the money and run.
________________
Steve Chryssos
Ridetech.com
Old 04-21-2009, 11:56 PM
JamesJ JamesJ is offline
Traco Engineering was based in culver city CA, they made hi performance engines back in the day. No idea if they are still around.
James J.
Old 04-23-2009, 12:26 PM
Desert68 Desert68 is offline
http://www.tra-coracingengines.com/history.html
Old 04-25-2009, 12:35 AM
chicane's Avatar
chicane chicane is offline
As the above link shows... JJ is still in business... the name is just a little different from what Jim Travers and Frank Coon started. Jim sold the business in the 90's along with the original name and went to work for Callaway to head up their engine development program... and then onto other things later. Anyway... he's still the same ole JJ I used to work with... only now he playing with some insane LSx derivatives. Good people...
I'd probably call him and tell him what you have... you never know, there may be someone looking for that specific head. None the less... he could tell you more about them than anyone else could.
I do know that in the early 90's he used to get a little over $3k for those heads.
Old 02-28-2022, 07:49 PM
Roybalgene Roybalgene is offline
Default Traco
Evilz are the traco heads available thanks!!!
Gene
303 919 6450
