Old 04-23-2009, 04:04 PM
Swain's Avatar
Swain Swain is offline
Default 9" housing
I am almost finished with my mini tub install on my 68 camaro, I want to know what is the recommended housing length. I will be using the Chassis Works G Bar...
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 04-24-2009, 04:35 AM
ibdmann ibdmann is offline
Swain my car is 69 camaro that is mini tubbed also and i'd like to install the g-bar too. The rear in mine is the stock width and I Have 325's under it. I'm in Huntington Beach if you want to come look at what this off-set looks like. With a 714 area code you are close
Old 04-24-2009, 08:53 AM
Swain's Avatar
I live in Huntington, I have a 9" out of a truck so I wanted to cut it down. I talked to mark at DSE they say 54.750 from outside axle flange to outside axle flange. 18x11 with 5" back space. What size wheels are you running?
Jay
Jason Swain
Old 04-24-2009, 04:07 PM
The car is not finished yet. I've got the original c-6 z06 rims front and back off my corvette for now. Had to actually add a 1 inch spacer on each side in the back to allow them to fit. In the back they are 19" by 325 width. Those rims are just to have something to mount on the car. I'm within walking distance of golden west college.
