Old 05-05-2009, 12:10 PM
KeislerJeff's Avatar
KeislerJeff KeislerJeff is offline
Default Keisler T45RS v. Muncie side by side
Check out the profile comparison of Keisler T45RS v. Muncie:
- Notice the Muncie is actually taller than T45RS at the case/extension joint
- Originally designed and made in Muncie, IN. The Muncie (est. 1929) and Warner gear (est. 1919) plants were just 3 miles apart!
- Fully synchronized including reverse, Muncie has no reverse synchronization.
- Same weight as Tremec TKO
- Low profile main case design fits many cars as well as Muncie, IN THAT AREA. Fits better than TKO IN THAT AREA ONLY.
- Not as broad as TKO due to single rail shift design but still broader than the Muncie.
- Much larger gears than the T5 equalling much greater strength. DO NOT CONFUSE T45RS WITH T5, THEY ARE GREATLY DIFFERENT.
- T45RS shares the same synchro parts as its big brother T56 6 speed for superior shift quality.
The Keisler T45RS has proven to be a robust and reliable 5 speed overdrive transmission. It is an excellent lower cost option to the TKO for those who do not require the TKOs strength or are working on a lower budget.
Jeff Kauffman
Keisler Engineering Inc.
www.keisler.com
888-609-0070 ext. 210
[email protected]
Keisler...#1 selling overdrive kit!
Join newsletter
Request a quote
Old 05-05-2009, 07:49 PM
JamesJ JamesJ is offline
Thanks for posting, I will have to share this with some folks, I know many people with 32 ford and such that would be able to use this.
Do you have a link to more info in this trans?
James J.
Old 05-06-2009, 05:33 AM
Default Keisler T45RS link
Here`s the link: http://www.keislerauto.com/index.php...350-lb-ft.html
The T45RS is an excellent tranny for street rod applications as well. We can move the shifter forward for bench seat clearance. The kit pictured is the 350 ft. lb. version, the 425 ft. lb. version is available and comes with a stronger 26 spline input shaft. We can put these behind a GM, Ford or Mopar engine. Thanks for sharing with your friends!
Jeff Kauffman
www.keisler.com
[email protected]
Join newsletter
Request a quote
Old 05-06-2009, 07:28 AM
wiedemab's Avatar
wiedemab wiedemab is offline
Are there other gearing options for these? I have an older Tremec 3550 in my Mustang, which has a 3.27 1st gear. It is really low, even with my 3.55 R&P.
I would love something in the 2.95 range for 1st, but I don't want the T5.
I just thought I'd ask - Thanks
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 05-06-2009, 07:43 AM
Default Keisler T45RS gearing
Eventually we may look into offering another gearset but right now they will be eqipped as follows: 3.37 1st 1.99 2nd 1.33 3rd 1.0 4th and .67 5th o/d.
Jeff Kauffman
www.keisler.com
[email protected]
Join newsletter
Request a quote
