Old 05-07-2009, 05:05 PM
g_vanlaar g_vanlaar is offline
Default 17 x 9.5 front on 1st gen camaro?
I know I've seen one car on here with a 17 x 9.5 and a 245 tire on the front of a 1st gen camaro. Will a 275 fit? If so what is needed to make it work? Thanks!
Old 05-07-2009, 05:11 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Scroll down to "How To Swallow a 275/40/17 Tire On All Four Corners" on Carl casanova's page: http://www.geocities.com/casanoc/
By the way, Carl's now running 285/40/17's at all four corners.
Old 05-07-2009, 05:18 PM
Good info. I wonder if the speed tech arms allow for more clearance than my global west arms?
Old 05-07-2009, 06:00 PM
Flash68's Avatar
Flash68 Flash68 is offline
I have a 18x9.5 with a 275 front on stock subframe. Preliminary turning radius seems okay (may not bump stops) but I will have it on the road in the next week or so for testing....
And I read CarlC's page too before proceeding.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-08-2009, 05:06 PM
z4me69 z4me69 is offline
flash what back space did you end up with ??
Old 05-08-2009, 06:26 PM
Lenie's Avatar
Lenie Lenie is offline
17x9.5 w/255 tires.
Lenie
Old 05-08-2009, 09:43 PM
Flash68's Avatar
I lied. I looked back and the first front wheel I ordered was 18x9.5 with a 5.5" BS, and that didn't line up right. I blew it on that deal.
Sent it back and it came out as a 18x9 with a 6.25" BS.
2014 4 tap Keezer
Old 05-11-2009, 08:17 PM
Rhino Rhino is offline
It sounds as if the first point of contact is typically the stock frame. If you weren't to contact the rails, at what point do you run out of room in the inner fender?
My plan is for a front sub based upon C5 components, with narrower rails. I'm undecided on front wheel at this point. I'd love to fit a 9 to 9.5" wheel (either 17 or 18) with no rub.
