Old 05-15-2009, 12:11 AM
AALynch AALynch is offline
Default Speedometer issues?
Hey guys,
I've got a '69 Camaro w/ an LS1/T56 in it. I'm using a Speartech new harness and Stewart Warner electrical gauges...I have HP Tuners for it if that helps in this any.
My speedometer seems to work just fine with the car, except for one thing. When I am anywhere from ~70% throttle to full throttle, the speedometer will spin to 120-140, and stay there until I let off the throttle. I'm not too knowledgeable in wiring, so...any ideas? The Speartech harness had a speedometer-labeled wire, so it runs straight to the input on the gauge...
Thanks,
-Adam
Old 05-15-2009, 04:45 AM
66LS7's Avatar
66LS7 66LS7 is offline
Default speedo
Originally Posted by AALynch View Post
Hey guys,
Thanks,
-Adam
Does the speedo bounce at idle? You might be picking up electrical interference from somewhere. I would try putting in a 1 micro-ferrid capacitor in the signal wire, one side of the cap. to the signal wire the other side of the cap. to ground.
Thank You Randy(D&Z Customs LLC.)
1-262-347-9741
Old 05-15-2009, 11:32 PM
Yes, I've noticed that!!! I just never cared much, because...well I was stopped and it doesn't matter LOL. When i'm accelerating, though, I need to know when to stop!
Thanks, I'll look into it.
-Adam
Old 05-19-2009, 11:20 AM
dhutton dhutton is offline
1-262-347-9741
1 microfarad sounds a little large. I would think it would kill the speedo drive completely.
Don
