Old 10-07-2005, 12:59 PM
4OfaKind's Avatar
4OfaKind 4OfaKind is offline
Cool Street King: Change of Plans ASAP!
You mentioned you were going to buy an Enzo before you die. I say don't sell yourself so short. I just got finished reading the C&D article on the Veyron "Transformer" the mad scientists at Buggati finally finished tweaking.
16 Cyl, 4 Turbos, AWD, AND a 7 speed DSG tranny!
Then @ 187 MPH it atuomatically drops from the 4.9" ride height to 3.2" and deploys a rear wing and underbody diffusers for stability and restraint. (Meaning they stabilize the car while at the same time governing the car to 187 MPH.) To go past 187 MPH you have to come to a complete stop, turn the keyed release located on the floor just in front of the driver's seat, and verify tire pressure (and that no one is in your way). The wing slides back in (but not completely), the diffusers close, and the height drops even further to 2"!
I say you sell every car you own (plus a couple of your neighbors') for the $1.5 mil it would cost to get one and watch every Enzo owner scatter like roaches after the "click". Not convinced? Chew on these numbers:
4300lbs
1,200+ HP
0-100 : 6 seconds!
1/4 mi in 10 seconds @ 140+ MPH!
Top speed 253 MPH!
15" Carbon/Ceramic Brakes (I forgot what the exact material is)
8 piston calipers Front/ 6 piston Rear
Panic stop w/ 2.0g of deceleration force!
Did I mention
Old 10-07-2005, 01:31 PM
tndude tndude is offline
Funny thing is....I'd bet his 69 Camaro would give that car a run for its money.
Old 10-07-2005, 01:53 PM
BC69's Avatar
BC69 BC69 is offline
I respect the pure engineering in a Bugatti, but I never really found them attractive. Id take an Enzo over that, and I still love the 430 Spider the best out of that line.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 10-07-2005, 03:27 PM
Blown353 Blown353 is offline
Keep in mind that at 4300 lbs the Bugatti is 1300 lbs heavier than the 3000 lb Enzo. That's a HUGE factor when it comes to handling. Also, the HP of the Bugatti is *only* 987, not 1200+. The horsepower gauge on the dash (seriously) only goes up to 1001. LOL.
Still an impressive car but given the extreme mass it may be a bit scary on a roadcourse. I was at the historics at Lagnua Seca when their test driver spun the 16.4 prototype off into the dirt at turn 3. LOL. The car is best suited for straight line and/or high banked oval blasts. Their goal was to create the fastest "production car"-- in a straight line. Also keep in mind the McLaren made 241mph and did so while being much, much more trackworthy at only 2500 lbs.
I'd still want one though, because it's an amazing design excersize.
The last silly-supercars I drove were an F-40 and an F-50. I'd have taken the F-40 over the F-50. I haven't had the opportunity to drive an Enzo and probably never well, but I would expect good things from it. I also bet it would be a blast to turn the "second key" on the Bugatti to turn the active aero features over to top speed configuration, find a long straight stretch, and hold the right pedal down for a good long time.
1969 Chevelle
Old 10-07-2005, 03:48 PM
Steve Chryssos's Avatar
That does it. I'm installing a "2nd key" in my Camaro.
________________
Steve Chryssos
Ridetech.com
Old 10-07-2005, 03:51 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
It is cool and fast , but for that kind of money it had better be. I don't know, it would be cool to see and (if possible) drive, but even if I had that kind of money I wouldn't buy one . That goes for the Enzo also for that matter, it is extremely cool and fast, but I just wouldn't look right getting in/out of one.
David
Old 10-07-2005, 07:05 PM
4OfaKind's Avatar
Default Yeah BUT...
As long as the track has 3 turns, you're probably right.
Keep in mind that at 4300 lbs the Bugatti is 1300 lbs heavier than the 3000 lb Enzo. That's a HUGE factor when it comes to handling. Also, the HP of the Bugatti is *only* 987, not 1200+. The horsepower gauge on the dash (seriously) only goes up to 1001. LOL. Still an impressive car but given the extreme mass it may be a bit scary on a roadcourse. I was at the historics at Lagnua Seca when their test driver spun the 16.4 prototype off into the dirt at turn 3. LOL. The car is best suited for straight line and/or high banked oval blasts. Their goal was to create the fastest "production car"-- in a straight line. Also keep in mind the McLaren made 241mph and did so while being much, much more trackworthy at only 2500 lbs.
Maybe the Enzo can corner better, maybe not. Sure the lighter car would be easier to handle going left & right. But even w/ 987HP (didn't the engineer say 1200hp in the article?) the Bug (ha ha VW - Bug) is only pushing 4.4 lbs/hp. That is two less than an Enzo. So getting off the line quicker and out of the corner faster w/ AWD, the advantage goes to the Bugatti. (If of course the driver is better than their test driver. )
I like the performance selection that allows AWD burnouts!
Not me. I thought 1k hp would be cool but after reading all the safety features designed into this car I think I will tone down my 56. If you turn the wheel too quickly while in "Ludacris Speed" mode the wing and diffusers come out to put the car back in the mode that limits you to 187 MPH. That's smart.
Old 10-07-2005, 07:58 PM
Streetking's Avatar
Streetking Streetking is offline
Bad ass car, but I still want a Enzo before I die..
SW
Old 10-08-2005, 11:43 AM
trapin's Avatar
trapin trapin is offline
To me, cars like the F-40/50 and Enzo are too much like race cars. I like mine to be a little more 'passanger car' like, if you will.
If I had $700,000 to spend, the first thing I'd buy is......well, a house actually. but if I had any left over it would go towards a 555 Maranello V12 or the Aston Martin Vanquish with Paddle-Shifted Manumatic trans and V12.
2 cars right there that really get my testosterone pumping. But to each his own.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 10-08-2005, 07:06 PM
lil427z's Avatar
lil427z lil427z is offline
enzo would be good .
rick kirkindall
