Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 05-17-2009, 08:25 AM
SVTforme SVTforme is offline
Default WTB - T56 Internal parts
Bought a trans that was put back together after someone pulled it apart and noticed that the blocker rings were shot and also the stamped keys were destroyed. They quickly put it back together and decided it was time to sell (I knew there were issues going into this). Unfortunately.. they did put these parts back in.. so I am now searching for them. Trans is a T56 from a 2004 Cobra (parts should be the same on most T56 transmissions).
- Parts 50-53 are just the front offset lever, spring and ball. These are the parts that are located under the stamped plate if you take it off (not sure why they would not put this back in).
- Part 78 (same as 76) is the spacer beside the roller bearing
- Part 108 is the thrust washer between the main countershaft and the countershaft extension (has an internal shoulder on it).
1969 Camaro RS/SS 76B
1968 Torino GT 4.6L S/C T56 IRS
www.twintorino.com
