Old 05-21-2009, 03:43 PM
jephs422's Avatar
jephs422 jephs422 is offline
Supporting Vendor
Thumbs up Prices too low to post on ALL Wilwood Camaro Systems...and free shipping
Okay the discount is too low for me to post, but be sure that you won't find a cheaper price on the following items. AND, I am offering free shipping.
You must tell me you are from Lateral-G to get the discount when you order. Please PM me or call here 805-485-0382
All the prices listed are jobber, call me or PM me for you price!!
1st / 2nd Generation Camaro/Firebird 67-69 / 70-78 OEM Disc/Drum Spindle - 10.75" Rotor Kit
PN1ST GEN----------------PN 2ND GEN------------DESCRIPTION
140-2285-B-----140-3445-B 10.75" ROTOR KIT, FDL 4 PISTON CALIPERS, PLAIN FACED ROTORS, BLACK CALIPERS 682.29
140-2285-BD-----140-3445-BD 10.75" ROTOR KIT, FDL 4 PISTON CALIPERS, DRILLED/SLOTTED -ROTORS, BLACK CALIPERS 785.69
140-2285-DP-----140-3445-DP 10.75" ROTOR KIT, FDL 4 PISTON CALIPERS, DRILLED/SLOTTED- ROTORS, POLISHED CALIPERS 888.95
140-2285-DR-----140-3445-DR
10.75" ROTOR KIT, FDL 4 PISTON CALIPERS, DRILLED/SLOTTED -ROTORS, RED CALIPERS 877.89
140-2285-P -----140-3445-P 10.75" ROTOR KIT, FDL 4 PISTON CALIPERS, PLAIN FACED ROTORS, POLISHED CALIPERS 785.69
1st / 2nd Generation Camaro/Firebird 67-69 / 70-78 OEM Disc/Drum Spindle - 12.19" Rotor Kit
PN 1ST GEN-----------PN 2ND GEN ------------DESCRIPTION JOBBER
140-7675-----140-8582 12.19" ROTOR KIT, FDL 4 PISTON CALIPERS, PLAIN FACED ROTORS, BLACK CALIPERS 748.74
140-7675-D------140-8582-D
12.19" ROTOR KIT, FDL 4 PISTON CALIPERS, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 852.93
140-7675-DP-----N/A 12.19" ROTOR KIT, FDL 4 PISTON CALIPERS, PLAIN FACED ROTORS, POLISHED CALIPERS 957.83
140-7675-DR-----N/A 12.19" ROTOR KIT, FDL 4 PISTON CALIPERS, DRILLED/SLOTTED ROTORS, RED CALIPERS 947.51
140-7675-P -----N/A 12.19" ROTOR KIT, FDL 4 PISTON CALIPERS, PLAIN FACED ROTORS, POLISHED CALIPERS 852.93
1st / 2nd Generation Camaro/Firebird 67-69 / 70-78 OEM Disc/Drum Spindle - DYNAPRO 6 CALIPER KIT
PN 1ST GEN------------PN 2ND GEN---------------DESCRIPTION JOBBER
140-10510-----140-10738 12.19" ROTOR KIT, DP6 6 PISTON CALIPER, PLAIN FACED ROTORS, BLACK CALIPERS 1046.52
140-10510-D-----140-10738-D 12.19" ROTOR KIT, DP6 6 PISTON CALIPER, DRILLED/SLOTTED -ROTORS, BLACK CALIPERS 1150.71
140-10510-DR-----N/A 12.19" ROTOR KIT, DP6 6 PISTON CALIPER, DRILLED/SLOTTED -ROTORS, RED CALIPERS 1295.03
140-10510-R-----N/A
12.19" ROTOR KIT, DP6 6 PISTON CALIPER, PLAIN FACED ROTORS, RED CALIPERS 1190.84
1st /2nd Generation Camaro/Firebird 67-69/70-78 OEM Disc/Drum Spindle -SL6 13.00" - 14.00" Rotor Kit
PN 1ST GEN----------PN 2ND GEN----------DESCRIPTION JOBBER
140-7019-----N/A 12.88" ROTOR KIT, SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, BLACK CALIPERS 1587.95
140-7019-D-----N/A
12.88" ROTOR KIT, SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 1689.50
140-7019-DR-----N/A 12.88" ROTOR KIT, SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, RED CALIPERS 1843.25
140-9803-----140-10485 12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, BLACK CALIPERS 1699.95
140-9803-D-----140-10485-D 12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 1802.25
140-9803-DP-----N/A
12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, POLISHED CALIPERS 1985.79
140-9803-DR-----140-10485-DR 12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, RED CALIPERS 1954.75
140-9803-P-----N/A 12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, POLISHED CALIPERS 1885.50
N/A-----140-10485-R 12.88" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED ROTORS, RED CALIPERS 1849.55
140-9804-----140-10486 14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, BLACK CALIPERS 1828.95
140-9804-D-----140-10486-D
14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 1929.95
140-9804-DP-----N/A 14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, POLISHED CALIPERS 2113.29
140-9804-DR-----140-10486-DR 14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, DRILLED/SLOTTED ROTORS, RED CALIPERS 2082.25
140-9804-P-----N/A
14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, POLISHED CALIPERS 2010.89
N/A-----140-10486-R 14.00" ROTOR KIT, RADIAL MOUNT SL6 6 PISTON CALIPER, PLAIN FACED GT ROTORS, RED CALIPERS 1977.65
1st/2nd Generation Camaro/Firebird 67-69/70-78 SUPERIOR 2" DROP SPINDLES 11.75"-12.19" Rotor Kit
For SUPERIOR SPINDLE 2" drop for 11.75" rotor only (no caliper brackets required or included)
PN 1ST GEN--------------PN 2ND GEN----------------DESCRIPTION
140-6713-B-----N/A 11.75" ROTOR KIT, FDL 4 PISTON CALIPER, PLAIN FACED ROTORS, BLACK CALIPERS 662.95
140-6713-BD-----N/A 11.75" ROTOR KIT, FDL 4 PISTON CALIPER, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 765.50
*For SUPERIOR SPINDLE 2" drop for 12.19" rotor only (no caliper brackets required or included)
N/A-----140-5770-B 12.19" ROTOR KIT, FDL 4 PISTON CALIPER, PLAIN FACED ROTORS, BLACK CALIPERS 662.95
N/A-----140-5770-BD 12.19" ROTOR KIT, FDL 4 PISTON CALIPER, DRILLED/SLOTTED ROTORS, BLACK CALIPERS 765.50
http://www.scottshotrods.com
