Old 05-22-2009, 09:58 PM
70rs's Avatar
70rs 70rs is offline
Default Which 5 or 6 speed?
Can anyone tell me which 5 or 6 speed trans will bolt up to a small block or big block chevy? If there is no direct bolt up, what parts are needed (flywheel,bellhousing)?
I may be wrong but I assume the 5 and 6 speeds meant for LS engines will not just bolt up and work.
Thanks for any help.
Eric
Old 05-23-2009, 07:01 AM
rjsjea's Avatar
rjsjea rjsjea is offline
http://www.keislerauto.com/ From the sponsor column to the left. They got everything you need.
Or www.prodigycustoms.com sells and has the information you would want.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 05-23-2009, 11:52 AM
70rs's Avatar
Thanks for the info. I sent Keisler a PM last night. I had info from Prodigy on this for use with an LS engine but I wasn't aware of any products for mating up to a standard small or big block.
I was going to go the LS way but the budget says otherwise now. I have a good 454 I can use and might have a fresh 327 as an option.
Thanks again.
Eric
