Old 05-23-2009, 01:51 AM
CamaroPat's Avatar
CamaroPat CamaroPat is offline
Default 295's on 9" wheels?
I'm considering 295's in the back, 275's in the front and I'm probably going to be using 17x9 wheels. I know the 275's will fit on my '81 Camaro. Is it wise to run 295's on 9" wide wheels, though? The aspect ratio will be 40. Is this too wide a tire with too short a sidewall to be worth using on a 9" rim? Some companies say it's fine and others don't when I use their compatibility guides and calculators. Just wondering what the maximum tire width for 9" wheel is. Thanks.
Great success rarely comes without the risk of great failure. '81 Camaro, 350, Edelbrock 750, headers, 4 speed, '97 Buick Park Ave Ultra, Supercharged 3.8L V6
Old 05-23-2009, 03:09 AM
BritishGreen68 BritishGreen68 is offline
Should work.. i have 305's on a 10 so i would think a 295 on a 9 would work fine..
Chris
Under construction-British Green 68 Camaro-
Old 05-23-2009, 08:20 AM
To narrow...A 275 calls for a 9.5-10 inch wheel. You could probably run a 9 with a 275.
Old 05-24-2009, 07:57 PM
CamaroPat's Avatar
I know for a fact I can safely run a 275 on a 9" wheel, but I think that's about as much as it'll handle. Rim selection within my budget has been a bit of a deciding factor. I know my car will accept a 10.5 rim in the back and 315's with a 5.5 backspacing. I've had trouble finding rims that I like (tasteful, not ghetto king, drug dealer stuff) that are available in both 9" and 10.5" widths in a 17" diameter with the right bolt circle, back spacing, etc. Oh well, if I run 275's all around I can rotate them and extend tread life and my engine's not so hardcore as to require anything bigger than a 275 out back. Thanks guys.
Old 05-25-2009, 02:35 AM
Alex396ss's Avatar
Alex396ss Alex396ss is offline
I think 295īs on a 9" rim will look too bulgy, but thatīs just my opinion...
Alex
- ī67 Chevelle SS396 - ProTouring project
- ī97 GMC Suburban - Family hauler
- ī07 BMW 335iAT M-sport - Daily driver
Old 06-04-2009, 07:06 PM
av8or32 av8or32 is offline
I've been wondering the same thing regarding 8" wheels. Is 255 as wide as I can go without looking too bulgy?
Old 06-05-2009, 06:28 AM
thedude327 thedude327 is offline
Are the 275's you plan on running using the 40 aspect ratio? Has your suspension been lowered at all?
Paul
1973 Z28 Street-touring project.........
Old 06-05-2009, 08:47 AM
rjsjea's Avatar
rjsjea rjsjea is offline
255/35 on an 8" wheel. Not bulgy at all
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 06-05-2009, 03:04 PM
Is that about max for a 8" or could I go wider without the bulge?
Old 06-05-2009, 03:05 PM
That looks awesome by the way!
