Old 10-09-2005, 06:25 PM
2kx2 2kx2 is offline
Default Painting the enigine?
What types of paints can you use on an engine block. I know of the high temp engine paints but they don't come in very wide variety of colors.
I have seen show cars with the engine painted the same color as the exterior. Is this simply regular automotive paint? Wouldn't the shine cook off from the engine temps?
Someone please help me with this delima. I would really like to do a paint match for the engine block and heads but don't know what types of paint to use.
Old 10-09-2005, 09:44 PM
protour's Avatar
protour protour is offline
A better question would include what parts you want painted?
My buddy painted his aluminum block.. Well not really, he polished it then cleared it with normal clear. It's still on there looking great.... LSX intakes have been painted and cleared with normal paint aswell.
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 10-09-2005, 10:34 PM
Musclerodz's Avatar
Most all paints will hold up on an engine block. The block itself will never get hot enough to cook the paint off it. You can paint it with just about anything you want. A trick to make spraybomb paint hard as hell is to bake it at 300* for 30 min after it has sat long enough for the surface to dry enough to handle. Just don't let your wife find car parts in the oven. Ask me how I know!
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-10-2005, 01:18 AM
evilzee28 evilzee28 is offline
Hi 2kx2, as musclerodz says, most paints will hold up on an engine, but preparation is very important. Make sure there's no flaky original paint on there, & absolutely NO oil. Clean the engine & all of the nooks & crannies with a wire brush & then wipe down several times with a degreaser prior to painting. Etch prime first with something like PPG Universel (acid based) & then paint with your chosen paint. For durability I'd spray it with a good quality 2k. I tend to spray engines without the thinners added as it has a higher build & fills in a lot of the small casting indents.... hth
Old 10-10-2005, 06:08 AM
Thanks for all of the replies. I am wanting to paint the block, heads, and accessories. The car is black and I'm, adding charcoal grey, and some red accents.
I want to paint the enigne charcoal grey too, since the valve covers are going to be black with chrome and red accents.
I was also told that you have to use a lacquer paint on engines.
Old 10-10-2005, 07:21 AM
TravisB TravisB is offline
Default NO lacquer
regular bc/cc will work great as everyone else has said! but do not use lacquer!
Kenny Davis Hot Rods
Old 05-06-2007, 07:04 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Would Epoxy make sence?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 05-07-2007, 07:10 AM
wiedemab's Avatar
wiedemab wiedemab is offline
I think that's a pretty good rule of thumb statement any more - that is unless you are restoring a grand piano.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
