Old 06-02-2009, 09:02 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default TKO TR-3550 5 speed trans kit
This is an early TKO kit- (I believe it's a Keisler trans kit, no receipts)
1. TR-3550 Trans (an early TKO, 425ftlb capacity), 4400 miles, has a mechanical and electronic speedo output. 3.27 1st gear, .68 overdrive. Info for trans from TTC (tag # 2600 708): http://www.ttcautomotive.com/English...ts/TR-3550.asp
2. Mcleod steel bellhousing+ adapter plate+ clutch fork + mounting bolts
3. Hurst shift handle with white ball
4. Centerforce clutch, USED (no flywheel) + mounting bolts
5. Keisler crossmember + mounting bolts
6. Trans mount
7. Z-bar assembly (not pictured, but complete- from the rod that attaches to the clutch pedal to the clutch fork) **I might be motivated to sell the whole pedal assembly**
8. Driveshaft assembly for a 1st gen / 12bolt (not pictured, in storage)
Trans is located at Jake's Rod Shop in Maine, $1300 + shipping PM me if you are interested.
JEFF
Old 06-03-2009, 05:07 AM
69x22's Avatar
69x22 69x22 is offline
Default 5 speed
How old is is and how many miles does it have? Any issues with it? does the shifter come through the factory hole okay?
Old 06-03-2009, 07:27 AM
ohcbird's Avatar
Default Tr-3550
The trans is 3 years old, and has about 4400 miles on it. The shifter hole on mine has been modified slightly, but it looks damn close!
I'll try to get a pic & measurement of where the shifter fits, but from what I've seen by the Keisler kits- these are setup to work with the stock shifter hole.
Old 06-13-2009, 03:26 PM
ohcbird's Avatar
Still for sale.
Here's a few pics of my crappy shifter hole:
Old 06-21-2009, 10:43 AM
joe67dk joe67dk is offline
Still have it? I PM'd you
Old 09-12-2009, 09:00 AM
ohcbird's Avatar
Still for sale...
Old 10-29-2009, 12:06 PM
ohcbird's Avatar
Default bump
TTT...still for sale. It will be coming down to FL in December.
Just to make this clear: I am in the military, currently deployed, AGAIN, and won't be able to ship it until I get back to Florida sometime in early December.
Jeff
