Old 06-05-2009, 12:32 PM
av8or32 av8or32 is offline
Default Has anyone switched over to a single wire alternator?
I still have the old style alt w/ext regulator. Has anyone upgraded to the internal, single wire type? What all is involved?
Old 06-05-2009, 12:49 PM
One hot wire. lol
Old 06-05-2009, 02:51 PM
Cool
Dude,
You know what I mean. I was looking for advice on switching over to a modern alt. w/an internal regulator. I don't have much electrical experience yet.
Old 06-05-2009, 11:20 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
Safely dead-head or remove stock alternator & regulator wires. For best results run a thick power & ground wire directly from alt to batt, 4 gauge? The thicker the better. Be sure to have good engine/chassis grounds and remember most 1-wire units require hitting a certain RPM before they "excite"
Old 06-06-2009, 08:06 AM
GM Muscle's Avatar
http://www.camaros.net/techref/ftecref14.html
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 06-06-2009, 08:57 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I suggest you read the relevant FAQ's at this site. It's pretty informative: http://www.madelectrical.com/electrical-tech.shtml
Old 06-06-2009, 09:33 AM
I'm running a 1 wire that came with my March set up. It does a fine job of charging the battery. My only gripe is when the battery is charged crusing the regulator over compensates and system voltage is at 13 volts vs 13.5-14 which is optimal. If your plumbing in a brand new systems I'd go with the 3 wire as suggested by mad electric.
Old 06-07-2009, 05:50 PM
Thanks everyone. Like so many others, I'm learning as I go.
