Old 06-06-2009, 12:34 PM
speedshftr speedshftr is offline
Default i shaved the trunk lock/latch questions
how do i go about getting the trunk opened now i shaved the lock/my budget is kinda strained so im thinking a cable? mabey run under the drivers seat?can you guys shed some light on this for me/thank you
Old 06-07-2009, 06:52 AM
SVPJason's Avatar
SVPJason SVPJason is offline
http://www.thehoffmangroup.com/autoloc/
Old 06-07-2009, 09:21 AM
porkchop's Avatar
porkchop porkchop is offline
Try control cables .com thats what I'm using.
Old 06-08-2009, 09:46 AM
redfire69's Avatar
redfire69 redfire69 is offline
modo innovations electric latch, $169: http://www.modoinnovations.com/id12.html
Ron
69 Camaro Redfire
Old 06-08-2009, 09:52 AM
Musclerodz's Avatar
Shannon's kit is nice. I have used several and sold a bunch of them.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-23-2009, 06:25 PM
i think that may be the best way to go/thanks
Old 06-24-2009, 04:23 AM
MODO Innovations's Avatar
Thanks for the recommendations.
This is a complete bolt in kit, I even have a simple sketch on how to make a cable pull set up incase you loose battery power and need to get into the trunk. Call me to get the sketch with you order 940-391-9002.
Thanks again.
Shannon
Modo Innovations
940-391-9002
Old 06-24-2009, 03:51 PM
shannon
one quick question/i dont have the key lock on the rear panel.if i have the electric button inside the car and hit the switch to open it will it fly open fast?i dont want the trunk to flip up fast.can it be rigged to just open the lock then ill have to lift the trunk myself?i will be buying this kit in the next week or 2 i just need to sort some things out.i checked your site out and i feel its the best latch system available for my application ,the 68 camaro trunk.thanks
Old 06-24-2009, 04:14 PM
Musclerodz's Avatar
How fast your trunk opens will depend on the trunk tension rods and how heavy or light the trunk lid is
Mike Redpath
facebook page
Old 06-24-2009, 04:27 PM
Mike is correct, the weight of the trunk lid depends on spoiler/no spoiler and body work/no body work (bondo) or a combination of both. The tension rods can be adjusted if need be. If you do adjust them be very careful, they are under alot of pressure.
Shannon
Modo Innovations
940-391-9002
