Old 06-06-2009, 06:30 PM
CE69 CE69 is offline
Default Motor Storage??
Very excited! Just bought a Pro-Charged 427! Pretty good deal and couldn't pass it up. Going to have to study up and learn more on pro-charged motors.
Problem is my car will not be ready for a motor for about a year or so. What is the best way to store or preserve the motor? I think I have some ideas like change the oil, drain the carb and tape up the exhaust ports. I don't want to back off the rockers if I don't have too, but will if necessary. What else can I do to help preserve the carb and cylinders and anything else that could go bad? Any and all help will be appreciated. Thanks
Old 06-06-2009, 08:39 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Climate controlled environment and turn it over once in awhile manually. Drain the carb, tape up the holes!
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 06-09-2009, 07:58 AM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
couldnt you just put it on a stand and run it everyones an awhile.
A man that's motivated will find a way.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
Old 06-18-2009, 07:24 AM
lewismd71 lewismd71 is offline
In addition, I would put a small amount of oil in the cylinders through the spark plug holes just to prevent surface corrosion. Then reinstall spark plugs.
Old 06-22-2009, 06:59 AM
69-X44 69-X44 is offline
I fogged my engine cylinders through the spark plug holes. Check out your local parts store and they should have engine fogger in a spray can.
