Old 06-06-2009, 09:29 PM
g356gear's Avatar
g356gear g356gear is offline
Default Brake line hook up for Willwood 6 piston calipers?
Does anyone know if Willwood makes a kit to convert the stock caliper lines to hook into the 6 piston caliper? The caliper switches from the rear of the hub (stock) to the front of the hub with Willwood. My kit did not come with anything to run from the old line to screw into the back of the new Willwood unit.
Old 06-07-2009, 04:27 AM
You need a new set of lines. There are lines specifically made to go from the frame and clip in as stock and then to the caliper. I have those kits in stock.
Frank Serafine
Old 06-07-2009, 11:58 AM
g356gear's Avatar
Hi Frank,
I sent you an e-mail. I would like to order a kit ASAP. Thanks.
Old 06-07-2009, 05:50 PM
Already sent Andrew a note to send a set out Monday. They are on the house!
Frank Serafine
Old 06-07-2009, 10:09 PM
g356gear's Avatar
Really ?! Frank you are the best. Cheers.
