Old 10-10-2005, 07:22 AM
2kx2 2kx2 is offline
Default Red anodized fittlings...
Does anyone make fittings that aren't red and blue? I am looking for fittings that are all red. Does anyone know if they produce them or how I could get some made?
Old 10-10-2005, 07:36 AM
TravisB TravisB is offline
have you talked to earls or aeroquip! I plan on using all black on my car!
Kenny Davis Hot Rods
Old 10-10-2005, 07:38 AM
I have seen the all black models and know they are easily available. I just haven't seen any that are all red and wondered if they were available anywhere.
Old 10-10-2005, 08:07 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I've never seen all red. Always red and blue.
I've seen all black, all silver, and I think all purple.
Old 10-10-2005, 08:38 AM
Matt@Lateral Dynamics Matt@Lateral Dynamics is offline
Buy and fit all your hose ends, ignoring color. Once they're fit, disassemble, and have them anodized any color you want. This goes for any aluminum part you want. It's critical to have them all anodized at the same time, in the same batch, or else the shade may be different.
Be forewarned, red and yellow fade the fastest due to heat and direct sunlight.
Old 10-10-2005, 06:54 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Check with XRP. I believe they have all red fittings.
Kurt
www.autokraft.org
Old 10-10-2005, 07:16 PM
Fluid Power's Avatar
Default fittings
Jegs....
http://www.jegs.com/webapp/wcs/store...tegoryId=28313
