Old 06-07-2009, 12:34 PM
GMracer's Avatar
GMracer GMracer is offline
Default Rules of filler, question.
So in my project I'm working on my tubs currently. Welding and smoothing them out as best I can, now I'm new on the body work thing, but I'm curious how flat the welds have to be before using filler. Basically one side is flush and you can see a line on the other side, I don't want to risk welding it anymore since it's so thin. But will I have a issue spreading filler over a weld that isn't perfectly smooth? A friend said it had to be perfect or it'd create an air bubble.
By the way, this is going under line-x I just want it as smooth as possible before hand.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 06-07-2009, 12:39 PM
nonova0074 nonova0074 is offline
Yo want the panels to match always use the least amount of filler. If the panel is to thin then you need to think about replacing it. Idf you are using line-x, it dosent have to be perfect. Juast make your you sand it nice and prime it well. I would self-etch prime the panel before body work, so you get it in all the cracks.
1974 GTO 400/m21
Getting ready to build her!!
Old 06-07-2009, 01:57 PM
elitecustombody's Avatar
try hammer & dolly before filler,usually it helps
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-07-2009, 07:36 PM
GMracer's Avatar
Thats what I was thinking, it's not super thin, just would be easy to skim coat it, I'm not talking very much. But I was thinking about the LINEX also, probably don't even need to worry about the part I'm talking about. I'll get some pics... thanks guys
Nick Schiffer
Special Thanks to:
Old 06-08-2009, 07:54 PM
GMracer's Avatar
I got it nice and smooth, just had to turn my welder down a bit.
What do you guys like for filler? Rage?
Nick Schiffer
Special Thanks to:
Old 06-09-2009, 10:00 AM
Rage Gold or Rage Extreme
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 06-09-2009, 07:53 PM
GMracer's Avatar
Thats what I figured, thanks man
Nick Schiffer
Special Thanks to:
