Old 07-06-2009, 03:52 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Does anyone know how to make a cockpit adj sway bar work
Hello:
Does anyone know how to make a cockpit adjustable sway bar work on a 1st Gen Camaro (69) I would really like to put on in the car, but, but finding the right part source and people with the expertise is fairly difficult.
Any help appreciated.
Thanks,
Ty
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 07-07-2009, 08:22 PM
JRouche JRouche is offline
Originally Posted by tyoneal View Post
Hello:
Thanks,
Ty
Parts.....
http://www.hrpworld.com/index.cfm?fo...ction=category
http://www.genesisparts.com/index.cf...action=product
As for tech advice. I called GT and spoke with a tech guy. Very informative and was willing to take some time. Also called HRP and got a knowledgeable guy on the phone. Sorry, no personal experience from me though. JR
Old 07-08-2009, 02:48 AM
tyoneal's Avatar
JR
Thanks for your input.
The products look really nice $$$$$, I'm just trying to find out how to make them work on my car. Would be nice to adjust on the fly.
I'll give them a shout and see what I can find out.
Thanks a lot for you help.
Best Regards,
Ty O'Neal
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 07-10-2009, 11:43 AM
Bryce Bryce is offline
one idea i had a while back....
currently how are most sway bars adjusted to change stiffness? the length of the arms are changed.
how about a linear actuator instead of the arm, this can be adjusted from the cockpit. it needs some fabrication and R&D to get the stability of the arms correct.
my idea directly changes the affectivness of the sway bar. the arms that rotate, change the force required to bend the arm. so the arms are bending as the sway bar starts to work.
Old 07-10-2009, 11:14 PM
B_Alley B_Alley is offline
That's a good idea. I'd like to try implementing something like that... the blade style, as shown above, has a real problem with consistency and linearity, but it does work as far as 'booger' and 'unbooger' wedge. We had servos that turn the blades to adjust from the steering wheel, but I like this method much better!
Bobby Alley
Old 11-13-2010, 03:24 AM
tyoneal's Avatar
Your comments are interesting. Any chance you would give these a try?
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 11-13-2010, 07:03 AM
not on my falcon. I just dont think that car will be competive enough for something like that. But I have a project in mind that would be a great canidate for something over the top like that.
Old 11-14-2010, 11:14 AM
exwestracer's Avatar
exwestracer exwestracer is offline
On the eastern supermodifieds, we use a hydraulic self-leveling system for the active top wing. Basically it's 2 small hydraulic cylinders plumbed in an X fashion. I've often wondered if a the same setup used as end links would work with a BIG bar. A flow control valve could be mounted inside the car. Fairly complex, yes... Just tossing the idea out there.
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 11-16-2010, 02:13 AM
tyoneal's Avatar
That sounds like some interesting technology. I'll see what I can find..
I'm really looking for ways to fine tune a car, "on the fly". You could then learn very quickly what influences what. Yes you can read about it all day long, but feeling by the seat of your pants from lap to lap should help you dial in:
1) After reading what makes the car do, or handle "this" or "that" way.
2) What type of characteristics you find most comfortable for your driving style.
3) For what Track time cost and your ability to get there and practice, having things very easily to adjust should maximize your learning curve. (Along with plenty of private lessons. Not necessarily in this order.
4) The less time you spend doing things the slow way, makes doing things the fast way a lot less expensive. I would bet if one could do a legitimate study, and had the funds to do so. Putting in these types of features would get everyone to their goal of being a respectable drive very quickly and possibly for less money.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 11-16-2010, 02:42 PM
Ty
If you combine the adj. bars with remote adj. shocks, you should be able to dial yourself out rather quickly...
Of course the results might be skewed by the weight of the "riding mechanic" you'd need to twist all the knobs for you.
Over the years, I've been involved in a lot of testing, and a big part of it is talking to the driver during downtime for changes to the setup. Too many laps and on-board changes, and drivers tend to forget what they did and how it really affected the car. Just my $.02...
