Old 07-20-2009, 04:21 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Default Trans cooler recommendations
Currently a Turbo 400 in the 69 cam --and may end up with a gear vendors. If not, an overdrive will make it's way in.
Car will be autocrossed, some open road events, a lot of street time.
Also, are any of you guys running your trans coolers in series with the radiatior? I'm in so cal, so not worried about needing to get the trans warm quickly in cold weather--but understand from an increased capacity standpoint it makes sense.
As always, thanks for the information. At some point I need to put pics of the car up---maybe a camera for Christmas---
Doug
Old 07-21-2009, 05:33 PM
DFRESH's Avatar
So, in the abscence of responses, I ordered a "Setrab" model--would still love to know if any of you are running your trans coolers in series with your radiator.
Old 07-21-2009, 06:29 PM
ElkyZO6 ElkyZO6 is offline
I'm running a 700r4 with a cooler and the radiator cooler. I going to upgrade to a big cooler with a fan before I run on the track. Just remember that heat is the number one killer of auto trans.
