Old 07-20-2009, 05:34 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Home stretch and need some help
I'm getting ready to do a c5 brake conversion to my 69 camaro. I already had the calipers/rotors but purchased the parking brake and install parts from Kore 3. Tobin is the man by the way. Anyways just looking for some feedback on what you guys are running for master cylinders....size make etc. Manual and power brake combo's would be much appreciated......Hopefully I'll have this thing done for Woodward.
Also my cam is a hydraulic roller. It's 242/250 at .50 and .590/.590. LCA is 114 and is currently installed at 111 (not sure if that makes a difference.) Will I have enough vacuum for power brakes?
As always thanks in advance
Old 07-20-2009, 05:53 PM
brans72 brans72 is offline
I will give you the anwser Andrew states 15/16 from 76 malibu with manual brakes and 6 cylinder and Tobin gave me 15/16 master cylinder from CPP M-C1516-S Small fitting, 15/16” Bore price $59.00 This price is cheaper then a new one at your local parts place. My .02
