Old 10-19-2005, 01:24 PM
MaxHarvard's Avatar
Default fiberglass or steel?
Ok fella's, if you remember correctly i did make a center console out of vinyl for my car about 2-3 months ago, and to be honest, i'm not too thrilled with it. Everyone else seems to like it but me. So my new plan is to make a new one, hopefully this one will be more to my liking.
The question is, do i make a mold and fiberglass it or do it bend some steel and weld it?
Whats your guys' thoughts?
Old 10-19-2005, 01:38 PM
TravisB TravisB is offline
Most upholstry(spelling) guys use wood and aluminum...this is just what I see being done by the guys that are real good at it!
Kenny Davis Hot Rods
Old 10-19-2005, 01:53 PM
MaxHarvard's Avatar
i made my first one out of MDF, but that was too flimsy i felt. Just didnt feel like it would last. Maybe its my imagination, or maybe i'm just too picky.
I've been told that Birch plywood works the best. The only reason i was considering fiberglass is because i do have some experience in it, and the console i have in mind has some odd shapes to it.
Old 10-19-2005, 04:59 PM
dry floral foam, bondo, make a mold, make a fiberglass part, cover in your choice of materials including paint..... when everybody with a camaro likes it, make some more parts and sell em off to re-coop your investment in time and materials.
using the floral foam works out killer, as it is really workable, finish coat it with body filler to the point of makin a mold...then its just like any other fiberglass part.
Old 10-19-2005, 05:30 PM
MaxHarvard's Avatar
I really want to use floral foam... where can i find a piece big enough? to make a mold?
Old 10-19-2005, 06:25 PM
ProStreet R/T ProStreet R/T is offline
Check the crafts stores, michaels, stuff like that, they should have some fairly large pieces to play with. You can hotglue pieces together if they don't have one massive piece.
Old 10-19-2005, 07:10 PM
MaxHarvard's Avatar
The biggest one i can find is pretty small. I've already been to several fabric stores.
Old 10-19-2005, 07:23 PM
i usually get it from a craft store...comes in "bricks" about 6x3x12", they also have a spray contact adheisive... that you can glue the bricks together with to get one big chunk... make sure to stuff some wood dowels in to help hold it together... as the glue works...but with the constant flexing from sculpting... the dowels do a better job untill you get a coat of filler over it to hold it all together.
btw........ when you start "sculpting" your gonna make a HUGE mess of green fuzz/foam chunks.... so make sure the shop vac is handy...especially if your doin it "in" the car
Old 10-19-2005, 07:27 PM
almcbri's Avatar
almcbri almcbri is offline
I have seen them made with wood, or fiberglass. My buddy builds them with Fiberglass and they are pretty amazing. I honestly don't know the process of building one. 69ZZ3 on the PT board has a cool console made from wood.
Old 10-19-2005, 09:19 PM
Floral foam is old news. 2 part Urethane foam can be glassed right over with no bonde or sealer, and can be poured / molding into a peliminary shape. Go to your local automotive parts store.
But with all that said, MDF is fine.
