Old 08-04-2009, 09:06 PM
1Bad67 1Bad67 is offline
Default Muncie dimension needed
Does anyone have a muncie they could measure the c-c distance between the main shaft and the counter shaft on?
Thanks,
Eric
Old 08-07-2009, 10:03 PM
67ragtp 67ragtp is offline
Eric,
3.25" +/- .010 with 1" counter shaft(cluster gear shaft)
Big hole at the mid plate in the case is 4.650"
little hole for cluster shaft .996
space between them .425"
Hope this helps - Rich
Old 08-09-2009, 10:23 PM
Thats what I needed. I wanted to hear 3.000 though
Thanks,
Eric
Old 08-10-2009, 05:15 AM
Eric,
I think the centers woud be closer to 3.0" if you were using the 325 case which uses a smaller cluster shaft(I could be wrong). I believe the shaft is around .750" . Dont have the small case here to measure, if this is the reason your coming up short, Jody at pro-touring.com from jodys transmissions could probably get you the dimensions.
Rich
