Old 08-14-2009, 12:10 PM
Fluid Power's Avatar
Default Window issues in my Silverado
2000 Silverado, driver's side window will not roll down, power windows. Bought window motor and new switch, still will not work. Passenger side works fine, even with new switch. There is a clicking noise that I traced to under the dash to a relay. Swapped them out, still doesn't work. It is not my daily driver, but I would like it fixed. Any ideas?
Darren
Old 08-14-2009, 01:53 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
May sound funny but, maybe disconnect the battery and reconnect to see if that resets something?
GOOD LUCK!
Old 08-14-2009, 02:15 PM
4cefed 4cefed is offline
Easiest thing to do is start with the basics. Check the PWR window fuse and to also make sure you have 12v on both sides of the fuse. If its ok, the green wire coming into the switch is your 12v hot, it comes from the fuse panel. Take a test light and make sure with the key on its hot. If not, the wire is likely broken ( if so check the pillar where the harness passes through).
If all that checks out, the window switch has two wires coming out of it that go to the window motor. Unplug the two wire connector between the motor and switch and take a test light and hook the alligator clip to B+ and backprobe the window switch side of the two wire connector. The two wires coming from the switch should both be grounded. If one, or both are not you either have a bad ground ( which for the window switch is behind the left kick panel ) , a broken wire, or a faulty switch. Even though you have a new one, it could still be faulty. Trust me
If they are both grounded then we move to the next step. One of those two wires, depending on which way you hit the switch, will turn 12v +. Make sure one done this on up, and the opposite wire on down.
If they dont, and all other things check out (as stated above) you have a faulty switch. If the switch works, unbolt the motor from the regulator and see if it operates. If it does, your regulator is bound up. If it doesnt, you have a bad motor. Easy way to test the motor, hook up a power and ground to it, doesnt matter which way you hook it up, it will spin right or left.
Old 08-14-2009, 02:59 PM
4 cefed. Thanks a lot for the help. I will do those things and see what happens!
Old 08-15-2009, 11:40 AM
Well did ya get it figured out?
Old 08-15-2009, 11:46 AM
pwr window fuse is good. power at both sides of fuse is good. pwr at switch, but there is a clicking noise in the relays on the floor, the are hot. Took them out, emery cloth, re-installed. nothing. bang and cuss and then the window works! lube everything well, and start truck to move out of shop, and window doesn't work, clicking noise back. connect switch back to motor and back probe the wires, .7 and -.7 gives me this reading on the old window motor and the new window motor.
Old 08-16-2009, 06:41 PM
04Prox2's Avatar
04Prox2 04Prox2 is offline
I have an 03 and my drivers side just stopped working, after reading this i'm not overly excited to try and fix it.
view all my junk here...
http://www.fquick.com/04prox2
Old 08-16-2009, 07:13 PM
JeffT JeffT is offline
My money is on a bad regulator.
Old 08-17-2009, 04:31 AM
my money is on bad wiring in the door or the harness thru the door into the body. It is an intermittent problem at this point. New reg. old reg, new switch old switch, any combo it doesn't matter. Voltage at the switch sometimes...the search continues....
Old 08-17-2009, 07:22 PM
For those who care, bad ground at the ground pack by the floor in the drivers side. Spliced in a new ground, self tapper to the door, good as new.
Darren
