Old 08-19-2009, 07:30 AM
GMracer's Avatar
GMracer GMracer is offline
Default Rattle Can Self Etching
Is it safe to use rattle can self etching before spreading filler? Or should I spray it. I want to do some of the filler work myself to help prep for paint and I know rattle can is a big no for finish work but wasn't sure if it's the same for under the filler.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 08-19-2009, 08:51 AM
68protouring454's Avatar
never etch prime under filler, or apply filler over etch primer. if metal is clean properly, putting filler on it is no issue. If your concerned use a epoxy primer on the bare metal areas, then sand with 120-180 then do filler work
jake
Jake's Rod Shop
Old 08-19-2009, 04:12 PM
GMracer's Avatar
woops I feel like an idiot, I knew it was epoxy no self etch but for some reason kept telling myself self etching. Thanks for the heads up, any reason epoxy in rasttle can would be an issue?
Nick Schiffer
Special Thanks to:
Old 08-19-2009, 07:42 PM
LateNight72 LateNight72 is offline
What type of "epoxy" is it? There are a few companies that make "epoxy" paints and primers in cans that are nothing more than lacquer.
There are also a few companies that are producing legitimate 2K epoxy primers in rattle cans. However they're $20 a pop.
Old 08-20-2009, 10:27 AM
GMracer's Avatar
I'll buy whatever need be, I have an autobody supply shop around the corner.
Nick Schiffer
Special Thanks to:
Old 08-20-2009, 12:02 PM
Rattle cans are a 1 part system. Your not getting the hardener in a rattle can. An epoxy is a 2 part material so you'll have to spray it like normal.
Jeff Allen
J2 Speed and Custom
Old 08-20-2009, 01:01 PM
GM Muscle's Avatar
there are a few rattlecan 2 part primers out there that are one time use. they have a pouch in the bottom with hardener in them that you have to puncture. then shake and spray..
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 08-20-2009, 01:36 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Hey GM any pics of your car you can share?
Old 08-20-2009, 02:55 PM
standox makes a 2 part epoxy rattle can as well, one can goes alot further then you think
its called ep pre coat
Jake's Rod Shop
Old 08-20-2009, 05:25 PM
GMracer's Avatar
thanks for the info guys!
https://lateral-g.net/forums/show...=16721&page=21
its no car, but a truck
Nick Schiffer
Special Thanks to:
