Old 10-24-2005, 12:28 PM
Payton King's Avatar
Default Mcleod adjustable Master for LSx T56
Hi All!
I have a Mcleod adjustable master for LS1/6 style T56 transmisson. The rod has been shortened to work for a 69 Camaro stock clutch pedal.
Basically, if you are doing an LS1/T56 swap into your 69 camaro all you need is the bracket that goes behind the brake booster and this will bolt right up and go to the pre-existing hole in the stock clutch pedal.
I went with a different style clutch that I have to use a stock master. This unit has never been used (mock up purposes only)
They are $306 new and it cost $30 to have it shortened and re-threaded.
$275
Old 10-26-2005, 12:41 PM
Default anyone want to make an offer?
anyone? Make me an offer
