Old 08-20-2009, 04:33 PM
donaz donaz is offline
Default looking for hub mounted jack stands
I've seen project cars on TV using hub mounted jack stands and am looking for a source.
Old 08-23-2009, 12:23 PM
Just make some!!
LOL
I've never seen anything like this 'for sale'.... but it wouldn't take much to make some wheel adaptors and weld 'em up to a set of jackstands.
Old 08-23-2009, 12:51 PM
They definitely have there place during a build.
Old 08-23-2009, 01:07 PM
If you don't know what your wheel bolt pattern is --- here's a link to a webpage showing how to measure that.
http://adaptitusa.com/index.asp?PageAction=Custom&ID=4
Might be just as easy and "cheap" to buy some wheel adaptors -- they'd already be drilled and ready to go -- then you'd just have to weld 'em up to
the jackstands.
You can't weld to cast iron - unless you're good - and then it needs to be preheated etc --- so if you are shopping for jackstands -- do yourself a favor and get SIX TON versions (they are taller - allowing better work height) - and get them with steel or cast steel (not iron) saddles.
Old 08-23-2009, 01:12 PM
By the way -- when I say wheel "adaptors" -- I meant wheel SPACERS - which should just be able to be bought in 1/4 or 1/2" (the version I'd by for this use) width - with the bolt pattern already drilled etc ---- You don't need the more expensive "adaptors" for what you're trying to do.
Sorry.
