Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 09-04-2009, 07:47 PM
scottguehne scottguehne is offline
Default Wanted: 67 Camaro rs parts
Hey guys, I'm in the st. louis area and in need of a few things for my 67 rs camaro. I need a passenger door shell, roof, 2 quarters, filler panel, fenders, header panel, cowl hood, seat covers, seat foam, maybe a rear end, and even a motor and 4 speed if anybody would happen to have one. I also need tail light lenses, and maybe housings if anybody has some real nice ones. I know this is a big list, but it is no where near a complete list. Basically, if you have good quality parts, let me know. I'm looking for just about everything.
A side question for anybody that reads this, how do I determine the displacement of the factory engine? Neither the cowl tag or the vin give that particular info, or at least not that I have seen. The vin just indicates 6 cyl or 8 I believe, but I'm not 100% positive.
I'm looking for a 12 bolt rear end, pretty much like everyone else. I currently have a 10 bolt, but it's a bit of a frankenstein. 10 bolt differential, with 12 bolt axle tubes. Crazy huh? I'm not looking for a "correct" rear end really, it could be aftermarket (strange,currie, whatever)
Thanks guys.
Old 09-04-2009, 09:24 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
I have a 67 mono-leaf 12-bolt rearend with a traction bar mount that I would sell, I have brand new Richmond 4:56 gears and install kit, stock axles and no brakes. I also have a 4-series positraction unit. It is not a rusty pitted housing, It has been blasted and rattle canned black. I have had the rearend for almost 20 years and has been stored inside the whole time and yes I am very proud of it.
I have a 67-68 bench seat with a fold down armrest that I might sell.
I have a pair of primered and used NOS 68 std fenders
I also have an NOS gm cowl hood for sale or 2 used gm cowl hoods
Tommy Lee
316-641-7962 cell
Tulsa Okla.
Old 09-08-2009, 06:34 AM
jy211's Avatar
jy211 jy211 is offline
I have this list left over from my 68' build...
New and Used Parts All from My 68’ camaro
Steering column - used
Side marker bezels – 2ea - used
Side marker light – red - used
Side marker light – white – 2 ea - used
Reverse lamp housing - used
a/c dash bezel and ball - used
rear view mirror - new
steering wheel with trim piece – new wheel, trim used
center consol emblem – new not in box
327 emblems - used
Camaro header panel emblem – 1 new not in box, 1 used
Sun visors – 2 pairs
Drivers side park lense – edge cracked - used
RH or LH windshield molding - used
Small block coil springs – used as mock up
Dash Cluster – speedo and fuel - used
Plastic dash cluster cover - used
4 speed tranny mount – used
Hood insulation fastner kit – new
68’ dash air duct seal kit – new
Cowl firewall seal kit – new
Roof rail weatherstrip – new
Center consol spring – new
Tank to filler hose – new
Horn cap mounting ring – new
RH and LH back up housings – new
Steering wheel install kit – new
Auto consol shift plate – new
Back up safety switch – new
Rubber vertical with steel inserts – new
Back up lens gaskets – new
68-69 camaro hdtp/conv dr.w/stripes w/ clips & molded ends
RS Headlight Parts – some new some used
Actuator brackets - new
Hinges - new
Vacuum canister - new
Headlight doors - used
Headlight assemblies – used
Headlight bezels - used
2 steering boxes
1 used – may be a OEM one
1 used – but like new maybe 100 miles on – quick ratio – just not sure if 12:1 or 14:1.
Old 09-08-2009, 11:59 AM
ragtop69 ragtop69 is offline
I have a complete m21 set up. It came out of my 55chevy. I went to a 4l80e. It comes with a freshed up trans, chrome blowproof bellhousing, centerforce clutch, pressure plate, 350 flywheel, and a hurst shifter. The clutch is in good shape. The chrome on the bellhousing isnt that great. It sat in the garage and didnt move for 20 years. That tends to affect chrome. Complete set up for $850. Trans has about 100 miles on rebuild.
