Old 09-05-2009, 02:40 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Default LS7 Crank Fitment
Will an LS7 crank fit in an iron 6.0 LS block? The crank I'm interested in comes out of a Z06. If so, will there be alot of stuff to do to make it fit, such as clearancing, etc?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-07-2009, 09:01 AM
Pantera EFI Pantera EFI is offline
Default LS-7 = Light Rods
I have installed the LS-7 crankshaft into LS2/3 blocks.
I used the LS-7 oil pan, oil pump, and front cover.
(dry sump)
The LS-7 crankshaft is balanced for the Ti Rods (very light) AND needed $600.00 of Mallory
to balance with the steel rods that I fitted.
A more cost effective 4.0" '4340' crankshaft ($550.00) can be found that will balance with steel rods.
Lance
Old 09-07-2009, 08:13 PM
214Chevy's Avatar
Thanks for the info.
'68 C10 swb
'72 Chevelle
