Old 09-06-2009, 04:21 PM
Brian Sanborn Brian Sanborn is offline
Default Wayne Due Subframe
I'm trying to sell a wayne due subframe for 67-69 camaros. This subframe is designed to use C-4 corvette control arms, spindles, sway bar, and a factory steering rack thats been narrowed. There are no motor mounts. When using the narrowed factory corvette rack, the engine needs to be set back 8 inches. I was planning on using a woodward rack and making new steering arms so the engine would not have to be moved so radically. The subframe comes with control arms, spindles, afco coilovers and 350# springs (for LS1 or aluminum small block), and coilover mounts for the lower control arms. I have corvette racks if you want to have one narrowed and set the engine back.
$3500 plus shipping
Old 09-06-2009, 09:18 PM
n2protour n2protour is offline
it would help if you let people know where you're located.
Old 09-07-2009, 07:52 AM
Manhattan, Kansas
Old 09-09-2009, 06:39 PM
keithcollins keithcollins is offline
Default sub frame
Could I get your number. Thank you.
