Old 09-08-2009, 09:40 AM
67rstbkt 67rstbkt is offline
Default 1988 Supra
****SOLD****SOLD******Located in Reno, Nevada
$3600 obo
Clean 1988 Toyota Supra, 219,000 on odometer (engine was replaced last year). The engine is a 7MGE 3.0 liter straight 6 It comes with the rims pictured as well as a set of 16 inch aluminum wheels with studded snow tires for the winter. The car has been lowered using an Eibach lowering kit. Has a Sidewinder alarm with keyless entry, Pioneer CD player and Kenwood amp. Newer paint and most of the interior has been upgraded/redone. I have receipts for just about all of this stuff. Everything listed has been replaced in the past year.
The good:
JDM motor (basically a used motor from Japan, has less than 40,000 miles)
Before we put it in the following was replaced:
Head gasket
Oil pump
Water pump
Valve stem seals
Timing belt
Fuel injectors
Other new parts:
Starter, O2 sensor, alternator, fuel pulsation damper, rear struts (KYB all around), new front calipers, new rotors, brake pads, battery, new tires, Magnaflow exhaust, and stainless steel brake lines.
The bad:
A/C does not work
The struts that hold up the trunk and hood need to be replaced.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
