Old 09-11-2009, 09:06 AM
g356gear's Avatar
g356gear g356gear is offline
Default TH400 speedo gear for bigger rims?
I have switched to 18" rims and a 35 series tires and was curious for opinions on what tooth number gear I should switch out to for my speedometer to be more accurate because it seems to be waaay off. I am running 3.37's and a Turbo 400.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
