Old 09-16-2009, 05:33 PM
Roblee67 Roblee67 is offline
Default welding body seams???
Has anyone ever welded together the front header panel / front valence to the fenders to make it one piece on a first gen camaro...Got any pics....looking for advise and opinions!!!
Robert Lee
1968 RS Camaro
2001 SS Camaro
Old 09-16-2009, 06:44 PM
HRBS's Avatar
HRBS HRBS is offline
Not a 1st gen Camaro, but we did this to a 64 Impala we built a few years ago. We welded every panel seam on this car except the actual operating panels (doors, hood, trunk). The front valance was welded to the fenders, the lower splash panel to the fender, the fenders to the front cowl, the fenders to the rockers and the rear quarters to the trunk filler panel etc etc.
Most people dont notice untill you say something.
Welding and body work:
After final prep:
Finished:
HRBS on Facebook
Old 09-16-2009, 07:07 PM
almcbri's Avatar
almcbri almcbri is offline
Here is a car that has it done. Looks pretty good in my opinion.
https://lateral-g.net/forums/showthread.php4?t=22416
Old 09-16-2009, 08:04 PM
That Impala is sweeeet.....Thanks for the pics, I have already done the splash panels to the fenders and I will likely weld the front valence and header panel to them also....Did you build some sort of removable bracket to attach at the upper back of the front fenders by the firewall (for stability) in case you ever have to remove the front end??
Robert Lee
1968 RS Camaro
2001 SS Camaro
Old 09-16-2009, 08:31 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I'm thinking of welding the filler panel to quarter seams on my Camaro, but then grinding the seam so it looks factory. That area is prone to body filler cracking.
Chris
Old 09-16-2009, 08:50 PM
awr68's Avatar
awr68 awr68 is offline
And seam sealer checking! That is why mine got welded......
Tony
'68 Camaro
Old 09-17-2009, 05:14 AM
HRBS's Avatar
Rob.... nothing is removable. The front end is now part of the car (and chassis for that matter).
The trunk filler panel is definetly prone to cracking. We welded the seam and then used lead to fill the remaining voids after grinding.
HRBS on Facebook
Old 09-17-2009, 03:57 PM
Okay -- I have the "stupid question of the week"...
Having this all as a solid unit -- doesn't that cause it to squeak etc?? I mean -- is there any "downside" to doing this?? Versus the upside to it??
This is all very interesting -- to me -- from a learning standpoint.
Thanks!
Old 09-17-2009, 04:22 PM
DRJDVM's '69's Avatar
I had thought about doing that to my car but the thought of having to remove the entire front assembly as one piece scared me off. God forbid you should ever need to remove a fender to get to something etc.... rather than taking off one or two pieces, you have to take the entire front end off...
That Impala is badass.....and it takes my concerns above and takes them up a notch Nice car...
Old 09-17-2009, 05:11 PM
HRBS's Avatar
Greg... no such thing as a stupid question (unless you ask me if that impala has hydraulics...lol). It actually helps eliminate squeaks due to less moving parts. There is less flex and body roll when the car is unified. As far as repairs.... well thats a different story. You hope with a car like this you dont have to. Then again if you have a car like this, you probably have the money to fix it if you ever need too...
HRBS on Facebook
