Old 09-30-2009, 07:16 PM
z585's Avatar
z585 z585 is offline
Default Hotchkis Chassis Max Handle Bar
Is anyone running this http://www.hotchkis.net/19671969_cam...ndle_bars.html looks kind of interesting. what are you thoughts?
1968 Camaro BBC 396
2007 TrailblazerSS LS2
http://www.joshuamccown.net
Old 09-30-2009, 08:42 PM
Looks super cool. Although I would not run it on a convertible. Firewall bracing on convertibles puts all the pressure on the door hinge pins and strikers, not too cool. On a coupe, they have to help. It is simple math.
If you want to try a set we still have our smokin 20% off Hotchkis special.
Frank Serafine
Old 10-01-2009, 04:06 AM
Neki67 Neki67 is offline
Frank,
I'ld love to purchase that from you but will it also fit when the Guldstrand mod has been done?
Old 10-01-2009, 02:31 PM
z585's Avatar
Does anyone know if it will stiffen up the handling, on a street car? Not autox or anything but really like the "ride on rails" feeling.
1968 Camaro BBC 396
Old 10-02-2009, 12:55 PM
Hotchkis Hotchkis is offline
senior member
You will find that it significantly stiffens the whole platform, eliminating body flex and definitely giving the "ride on rails " feel.
Old 10-02-2009, 01:07 PM
GeoffP GeoffP is offline
It doesn't look like it'll work on fuel injected cars that have LSx or LT1 engines if you're using a stock style intake due to the cross bar. Any solution in the works for that? Say a curved cross bar?
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 10-02-2009, 03:22 PM
I was hoping it would clear an LS engine since it sits lower than the old style engines but you may be right. An answer to that question from someone using it or the mfr would be highly appreciated.
Oh and there's still the question whether it would work with the Guldstrand mod or not!
Old 10-02-2009, 06:44 PM
Jar's Avatar
Jar Jar is offline
Originally Posted by Neki67 View Post
Frank,
That's a great question, it doesn't look like it would.
Old 10-03-2009, 05:04 AM
I would have to say no but maybe. If you did the G Mod by simply drilling a couple holes lower and kept the upper holes, it may still bolt into the original holes? Now I am going to have to try it...............After Barrett Jackson and SEMA.
In the mneantime I will get Hothkis to send me a set, I have the perfect car to test them on. but we may have to modify the cross bar as this car is supercharged.
Frank Serafine
Old 10-03-2009, 08:53 AM
Jar's Avatar
Jar Jar is offline
Awesome Frank, let us know.
