Old 10-02-2009, 08:15 PM
FastCat431's Avatar
FastCat431 FastCat431 is offline
Question Buick Grand National manual transmission swap
Was wondering if anyone out there knows if this is possible. I may be getting my hands on an 87 GN and thinking about trying to convert it to a 5 spd tremec, I know the clutch pedal would have to be fabricated but not sure I could even get a flywheel for the 3.8 v6. Any ideas?
Old 10-03-2009, 11:46 AM
Blown353 Blown353 is offline
Do some reading over on turbobuicks.com... manual swaps have been done in both the GN and also the Turbo Trans Am.
General consensus is all parties were less than impressed. Much slower overall response and "feel" as the 3.8 isn't the fastest spooling engine in the world.
Also, there can be some thrust bearing issues with the 3.8's and the added pressure of a clutch against the thrust bearing only makes that matter worse.
1969 Chevelle
