Old 10-04-2009, 06:00 PM
phillym5 phillym5 is offline
Default What shifter works best with T56??
My 69 camaro is almost done...!!
I have yet to pick a shifter.
What shifter is best to use for the T56(Tranzilla)? Im using the Gen 2 center consul... and it is a 6 speed.
thanks.
Old 10-04-2009, 06:38 PM
Aschle's Avatar
Aschle Aschle is offline
I have a T-56 in my 91' Camaro and am running a Pro 5.0 shifter. I absolutely 100% recommend it !!! I ran the stock shifter for a while... that sucked. I have driven a few cars with the Hurst, the B&M, and modified stock, and in my opinion, the Pro 5.0 is the best for being the most solid/ smooth shift. 2-3 shift has yet to be missed since install !
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
Old 10-04-2009, 07:03 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I have a pro 5.0 and it is not bad at all.
Scott from NJ
Last edited by BonzoHansen; 10-04-2009 at 07:04 PM. Reason: d'oh, you got a 1st gen
Old 10-04-2009, 07:15 PM
AALynch AALynch is offline
I've got a Pro 5.0 in my Camaro, and love the direct feel between shifts...it works great for me!
Old 10-04-2009, 08:05 PM
Steve1968LS2's Avatar
Another vote for the Pro 5.0
I had one in my 2000 SS and loved it.
Old 10-04-2009, 10:37 PM
Thanks for the movement into the right forum....
Looks like I will order a 5.0 tomorrow!!
thanks.
Old 10-05-2009, 07:40 AM
para67camaro para67camaro is offline
I also have a t56 but I am going to use the MGW one. Read the forums in ls1tech.com They have a lot of info on the shifters, and everyone is pretty adamant that the mgw is the best one out right now. You just have to break it in.
FYI thier site mgwltd.com does not have one for an fbody on the site. They do make one for a fbody t56 which is what you need, you have to call them to order it.
Old 10-05-2009, 03:17 PM
I do have the Marquez interior(dash and gen 2 consul)...
Am i going to need a bent back one?
Old 10-07-2009, 02:52 PM
comp-spec's Avatar
pro 5.0
Pete
Competition-Specialties.com
Old 10-07-2009, 04:03 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
You cant go wrong with the Pro 5.0
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
