Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 10-05-2009, 02:25 PM
almcbri's Avatar
almcbri almcbri is offline
Default WTB: 68 camaro grill parts
I am needing a few parts for my 68 camaro. It is just a standard front end.
RH headlamp bezel: 68
2-beam retaining rings:
upper grille trim: 68 standard
pair of parking lamps complete: 68
Grille mount brackets: 68
front spoiler 67-69
front spoiler bracket mounting set 67-68
all parts need to be in good-excellent condition. no damaged parts.
Thought I would ask here and see if anyone had any left over parts before purchasing from the classic chevy house.
pm me or email [email protected]
zip is 73134
Thanks, Andrew
Last edited by almcbri; 10-12-2009 at 07:07 PM. Reason: bought a LH bezel, lower trim on ebay
Old 10-12-2009, 07:07 PM
almcbri's Avatar
bump
Old 10-13-2009, 07:25 AM
jy211's Avatar
jy211 jy211 is offline
I have all this:
New and Used Parts All from My 68’ camaro
Steering column - used
Side marker bezels – 2ea - used
Side marker light – red - used
Side marker light – white – 2 ea - used
Reverse lamp housing - used
a/c dash bezel and ball - used
rear view mirror - new
steering wheel with trim piece – new wheel, trim used
center consol emblem – new not in box
Sun visors – 2 pairs
Drivers side park lense – edge cracked - used
RH or LH windshield molding - used
Small block coil springs – used as mock up
Dash Cluster – speedo and fuel - used
Plastic dash cluster cover - used
4 speed tranny mount – used
Hood insulation fastner kit – new
68’ dash air duct seal kit – new
Cowl firewall seal kit – new
Roof rail weatherstrip – new
Center consol spring – new
Tank to filler hose – new
Horn cap mounting ring – new
RH and LH back up housings – new
Steering wheel install kit – new
Auto consol shift plate – new
Back up safety switch – new
Rubber vertical with steel inserts – new
Back up lens gaskets – new
68-69 camaro hdtp/conv dr.w/stripes w/ clips & molded ends
RS Headlight Parts – some new some used
Actuator brackets - new
Hinges - new
Vacuum canister - new
Headlight doors - used
Headlight assemblies – used
Headlight bezels - used
2 steering boxes
1 used – may be a OEM one
1 used – but like new maybe 100 miles on – quick ratio – just not sure if 12:1 or 14:1.
