Old 10-12-2009, 03:59 PM
screamingscotty69 screamingscotty69 is offline
Default 1972 Nova 2005 Corvette
Brother in law has the following
Car: 1972 6cyl powerglide Nova 108" wheel base?
Parts Car: 2005 Corvette 6spd complete chassis and drivetrain 105" wb?
What is the best way to go about putting the two together?
I believe the best is to go std trans / motor combo w/ some variation of 9"
He wants to know if he can "stretch" the Chassis of the vette to work and put under the nova.
If he is stubborn on the IRS rear I believe full custom chassis will be in order.
Could someone please offer some guidance or suggestions on this project.
1969 Malibu
1989 Trans Am GTA
1998 GMC Sonoma
2005 Mazda 6 Wagon
1995 NISMO Factory Hardbody(daily beater)
Time you enjoyed wasting was not time wasted
Old 10-12-2009, 04:19 PM
almcbri's Avatar
almcbri almcbri is offline
sounds killer
Take some time and do some searches and ask questions in the specific cateories.
I know that their are some guys transplanting the complete drivetrain under camaros so I don't see why it couldn't be done on its cousin the nova.
Extending the driveline-(not sure the correct term) can be done.
You will need a jig if you plan on doing the complete suspension, but it is very do-able if you have the tools and skills.
One thing about it, you can always use the engine and back it up with T56 and go with an aftermarket subframe and rear. There are several vendors that could get you hooked up with the suspension you guys need.
Old 10-12-2009, 04:26 PM
Hi Scotty,
You can splice into the standard C5 corvette frame and extend it to fit into the wheel openings of the Nova. You will need to recess it into the floor of the Nova somehow - so the middle profile of the stock vette frame might cause you problems. You can also splice into a custom mid frame and add the vette front and rear frame stubs onto that if you wanted. In the chassis manual of the C5 corvette it explains the GM approved procedure to replace a damaged frame section. Anything is possible.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 10-13-2009, 10:04 AM
WILWAXU WILWAXU is offline
Call IronWorks
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 10-13-2009, 04:17 PM
HWY Nova HWY Nova is offline
Originally Posted by WILWAXU View Post
Call IronWorks
Exactly!
--Eric
ET
63 Nova Coupe
63 Nova Wagon
62 Nova Convertible
