Old 10-15-2009, 10:32 AM
hulsund hulsund is offline
Default brake kits
HELLO have someone any ideas about brake kit front and rear on an 1968 firebird ,will use 15" wheels on it.
maybe somone sale complet kits (willwood) ?
Old 10-15-2009, 10:56 AM
We can do the entire car with our Prodigy Customs Total Car G Machine Brake Packages including Wilwood front and rear kits, Braided hoses front and rear, E brake cables, Wilwood Dot 4 fluid, Master, prop valve, Safety wire and pliers, all for $1850
Here is a example of a kit, not excatly your kit though
This kit has optional red calipers, optional drilled and slotted rotors and optional polished stainless brake booster.
Frank Serafine
Old 10-15-2009, 12:44 PM
70rs's Avatar
70rs 70rs is offline
The kit Frank shows above is a great package.
Old 10-15-2009, 01:51 PM
fathomgreen69ss fathomgreen69ss is offline
Has anyone tried this kit out? I am looking to do a complete kit on my '71 Nova. Is this a direct fit kit, or does it require some modification?
Old 10-16-2009, 04:47 AM
The only mild modifications on your Nova would be you MIGHT have to tap a existing hole on a spindle and you will remake the axle tube brake lines. Also you will be re routing the new rear e brake cables to meet your original front primary cable. Nothing a home weekend mechanic cannot handle.
Otherwise a complete bolt in
We have sold 100s of these kits and are installed 2 kits in the shop this week. So we install what we sell, if you need help, were a phone call away
Frank Serafine
Old 10-18-2009, 06:24 AM
Sounds like exactly what I am looking for. I just don't know if I will be able to wait until Christmas. Looks like I may upset the wife yet again
Does it make any difference that my rear end has been slightly narrowed and I have C clip eliminators?
Old 10-18-2009, 04:38 PM
C Clip eliminators are a big problem. Wilwood does not make a kit for C Clip eliminators.
Frank Serafine
