Old 10-16-2009, 02:39 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default GTO Accessory Drive
Will the stock GTO LS2 accessory drive work in a first gen Camaro. I know the stock subframe needs to be modified for the A/C compressor, but does the stock alternator location cause a problem?
Chris
Old 10-17-2009, 09:38 PM
BillyBobL71's Avatar
BillyBobL71 BillyBobL71 is offline
Default It Will
Yes it will. I have this setup in my 69. the engine goes forward and up a little. You will need to modify the AC connection a little to clear the crossmember. Also, You'll need an LS1 Camaro pan to clear the crossmember also.
BillyBobL71
Old 10-18-2009, 09:10 AM
ItDoRun's Avatar
What motor mounts did you use? I planned on notching the subframe for the A/C compressor anyway.
Chris
Old 10-24-2009, 03:53 PM
Reckley's Avatar
Reckley Reckley is offline
Chris, I sent you a PM on this
Mike
Old 11-06-2009, 08:15 PM
ItDoRun's Avatar
Mike
Got it. I just haven't had a chance to give you a call.
Chris
