Old 10-19-2009, 11:33 AM
steinepstein steinepstein is offline
Default Installing hard lines for EFI
Wondering if anyone has tips of knows of a site on installing a hard line fuel system.
I have a 68 c10 and am converting it to EFI and have installed the tank in the rear of the truck. I'd like to run a clean and straight set of Al fuel lines on the rail.
Thanks,
JE
Old 10-19-2009, 01:58 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Is this an LS engine?
If so, you can get the actual nylon lines at NAPA as well as the ends and tool to press and build the system.
Old 10-19-2009, 04:10 PM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
All you need to know.
http://bentcustomandperformance.com/
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
Old 10-19-2009, 06:34 PM
Good stuff, thanks.
JE
