Old 10-19-2009, 01:00 PM
68protouring454's Avatar
Default Shocked Runs 9's
guys, its been awhile but vinnys 68 camaro shocked, just went 9.98 at 138.47 in the 1/4 mile at atco drag way. Pretty unreal for a pro touring street car.
We will post video later of the run. heres a pic and stats
1.53 60 ft
[email protected] in the 8th
[email protected] in the 1/4 mile
This is on a 100 shot, his progressive controller died last week and he is on a wot switch, he spins coming out of hole with nx armed, so on his 9.98 run he armed it just after launch,lol Once new controller comes in he will run it on 200 shot but dial it in over a few seconds, should run 9.70s easy.
Jake's Rod Shop
Old 10-19-2009, 01:12 PM
Yenko boy Yenko boy is offline
That's awesome!!!!!!!!! What are the dyno numbers on the motor and on the nitrous?
Old 10-19-2009, 02:07 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Good word!
Nice work!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 10-19-2009, 02:15 PM
comp-spec's Avatar
nice work Jake
Pete
Competition-Specialties.com
Old 10-19-2009, 02:19 PM
rogue rogue is offline
Nice Numbers!
Old 10-19-2009, 02:23 PM
nvr2fst nvr2fst is offline
Is the WOT set up for drive by wire. I thought you needed full throttle to activate properly, even in 1st gear. Must of had some serious RPMs off the line.
Very nice numbers!
Old 10-19-2009, 02:48 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Very nice numbers!
His car runs a carb if memory serves me correct.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 10-19-2009, 03:01 PM
BLACKJACK's Avatar
BLACKJACK BLACKJACK is offline
Thumbs up
SWEET
"SUNOCO TWIST"FRED https://www.youtube.com/watch?v=YfpTBwibHCc
Old 10-19-2009, 03:12 PM
Very nice numbers!
he left the line with nitrous off, the switch to arm the 2nd fuel pump and nitrous is on middle of dash, he flipped switch on once out of hole, not normal but worked for him, the progressive controller will allow him to dial nx in slowly, rather then one big hit.
engine is a 496 chevy bb, afr heads, 10.9-1,solid roller, pro systems carb etc.
Jake's Rod Shop
Old 10-19-2009, 03:18 PM
Looking at his ft. time, his timing on hitting the switch was pretty impressive.
Knowing hes 1/4 mile this car before, I wouldnt consider Vinny to be lucky and his experience makes a big difference.
Again great slip times.
