Old 10-19-2009, 09:10 PM
Default Opinions about a compressor.Quincy now or IR later
I have a chance to buy a Quincy QT5 2 stage its a 2007 it was used in a wood shop. It had a bad bearing and burnt the motor out . Quincy replaceds the whole compressor. The owner had it rebuilt with all Quincy parts and a new Baldor motor . 230 single phase. It doesn't have the dryer option. The tank is 80 gal epoxy coated inside the only thing missing is the belt guard. I can get it for $800 New their about $1700.It can put out 18.5 cfm at over 100psi.
What do you guys think? A new IR 5 hp 60 gal is $900 new. The garage isn't built yet but storing it is no problem.
Old 10-19-2009, 09:12 PM
68protouring454's Avatar
no question the quincy 2 stage, no brainer
Jake's Rod Shop
Old 10-19-2009, 09:39 PM
BUY IT !!
What are you waiting for??
Old 10-19-2009, 10:04 PM
caper150's Avatar
caper150 caper150 is offline
Get the quincy, I have an IR 80 gallon 2 stage and it's not that old, hardly and hrs and I just had to replace both the pressure switch and the motor, after some research found out that the motors on the IR's have a tendency to over heat, some have even caught fire(glad mine wasn't one)Leeson brand motors.
__________________________________
Darryl
My projects
1965 Ford Galaxie Big Block and 4Doors Project HULK
1966 Ford Galaxie 2 Door Sedan Project unnamed 4.6L Crown Vic runnig gear
Old 11-29-2009, 04:53 PM
moparnut moparnut is offline
Get that compressor! I have one and I have tried to kill it for 10 years, running it 4-5 hours everyday. It's a great compressor for the money.
Old 11-29-2009, 09:22 PM
70rs's Avatar
70rs 70rs is offline
YES BUY IT! The dryer can be added any time and you can make a belt guard pretty easy. Go for it!
Old 12-04-2009, 09:35 PM
elitecustombody's Avatar
Get Quincy,IR is junk ,cheater compressor
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 12-05-2009, 08:10 AM
MODO Innovations's Avatar
My IR had about 50 hrs on it when the 5hp. motor burnt out. My neighbor had the same thing happen to him with his 7 1/2 hp motor on his IR. Buy the Quincy.
Shannon
Modo Innovations
940-391-9002
