Old 10-20-2009, 09:43 AM
Hotchkis Hotchkis is offline
senior member
Default New- HOTCHKIS 1st Gen CAMARO HANDLE BARS
HOTCHKIS 1st Gen CAMARO HANDLE BARS:
NASCAR CHASSIS TECHNOLOGY FOR YOUR F-BODY
New Brace for 1967-69 F-Bodies Eliminates Flex, Improves Handling & Control
• Prevents changes in geometry, alignment, and tire contact patch
• Rigidly connects upper control arms to the cowl and firewall
• Bolt-on installation w/ included hardware
• CAD designed for superior fit and finish, designed and manufactured in the USA
Take a long look at a modern NASCAR cup car, a 1960s F1 car or a 3,000 year old Egyptian pyramid and you'll notice one similarity: lots of triangles. The triangle is the strongest shape in nature, so when a group of hardcore autocross racers asked Hotchkis to come up with a way to eliminate subframe flex in their First Gen Camaros, they looked to the past to define the future. The result: Hotchkis Chassis Max Handle Bars, the first tubular front suspension brace that triangulates the upper control arm pickup points to each other and the firewall for incredible rigidity, consistent driver control and handling.
First generation Camaros and Firebirds use a bolt-on style subframe that can twist and flex during hard cornering, altering suspension alignment and altering the tire contact patch, creating unpredictable handling at the limit. This problem is amplified in pro-touring style cars with sticky modern tires and high-power engines. To eliminate flex, Hotchkis to developed the Handle Bar system to tie the upper control arms to each other and then triangulate them to the firewall for maximum subframe strength and rigidity. The result is more consistent response, increased handling, and improved driver control that makes the most of any high performance suspension.
Handle Bars are CAD designed and built out of high-strength steel tubing, CNC bent brackets and laser cut gussets for easy installation and a perfect fit. All necessary hardware is included, and Handle Bars are available with a durable gloss anthracite powdercoat finish or in raw steel for those that wish to color-match their engine bay.
About Hotchkis Performance
Founded by former professional racecar drivers and national champions, Hotchkis Performance was one of the first to design and track test performance suspension for muscle cars. Nearly two decades later, Hotchkis remains dedicated to high-quality, track-tested, suspension that is Made in the USA with domestic materials. Dare to Compare: Hotchkis offers complete bolt-on systems that are designed in-house and rigorously track tested for maximum performance, strength and value. Each system is tuned for high performance handling, a sporty yet comfortable ride and improved traction on the street and track. Don't settle for pieced-together systems or foreign sourced parts. The Hotchkis Philosophy is simple: Buy it once, bolt it on, and have fun! To preview the entire line of Hotchkis Sport Suspension parts and components, please visit www.Hotchkis.net, email [email protected], or contact Hotchkis Performance, 12035 Burke Street Suite 13, Santa Fe Springs, CA 90670, 877-4-NOROLL.
Old 10-20-2009, 03:43 PM
redfire69's Avatar
redfire69 redfire69 is offline
Really interesting. Any estimated retail?
Ron
69 Camaro Redfire
Old 10-20-2009, 03:52 PM
senior member
Hi redfire, glad to see interest.
You can get all the retail information on the website here:
http://www.hotchkis.net/19671969_cam...ndle_bars.html
Old 10-21-2009, 04:37 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I'd like to see this on a LSX set up.Looks killer, I hope there out at SEMA
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 10-27-2009, 10:19 AM
Jay Hilliard's Avatar
Will it work with DSE coil-over conversion, where factory A-arm mounting plate has been removed and DSE plate installed?
Jay
Old 10-27-2009, 10:46 AM
jcal87's Avatar
jcal87 jcal87 is offline
Might be functional but very ugly in my opinion
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
